BT.com
Wishlist
Philips 246E7QDSW/00 24" 1920x1080 DVI VGA HDMI Monitor
Delivery
Standard 1-3 working days
Vivid, true-to-life colors in an elegant design. This brilliant wide view display with wider color gamut offers true-to-life colors wrapped in an elegance-inspired design for a light and fresh face in any home or office.
Philips E-line 246E7QDSW - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Energy Consumption per Year
39 kWh
Power Consumption (On mode)
27 W
Panel Type
Plane to Line Switching (PLS)
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.272 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
15 ms (typical); 5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA, MHL
Display Position Adjustments
Tilt
53.9 cm x 17.9 cm x 41.9 cm
3.18 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV, VCCI, C-Tick, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE, CECP, TCO Displays, CU-EAC
Display Type
Energy Class
Class B
39 kWh
27 W
Diagonal Size
24"
Viewable Size
23.6"
Panel Type
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.272 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, SmartImage Lite, SmartResponse, SmartContrast, 99% sRGB colour gamut, Flicker Free technology, Mercury free, 82% NTSC colour gamut
53.9 cm x 17.9 cm x 41.9 cm - with stand
3.18 kg
VGA , MHL / HDMI (HDCP) , DVI-D (HDCP) , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
MTBF
50,000 hour(s)
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.3 Watt
On / Off Switch
No
Apple MacOS X, Microsoft Windows 7 / 8 / 8.1
Dimensions & Weight Details
With stand - width: 53.9 cm - depth: 17.9 cm - height: 41.9 cm - weight: 3.18 kg , Without stand - width: 53.9 cm - depth: 4.5 cm - height: 32.4 cm - weight: 2.61 kg
ENERGY STAR Certified
20 - 80%
Accessories
£7.95
£8.90
£12.18
C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL
Quicklinx: 63SL | In Stock
£9.94
£6.00
£8.53
C2G 2m HDMI to DVI-D Digital Video Cable
Quicklinx: 915T | In Stock
£8.43
£56.40
Scroll to top
