BT.com
Wishlist
Philips 241P6VPJKEB/00 24" 3840x2160 VGA DVI 4K HDMI Monitor
Delivery
Standard Due date unavailable
This advanced Philips display utilizes high performance panels to deliver UltraClear, 4K Ultra HD (3840 x 2160) resolution images. Whether you are demanding professional requiring extremely detailed images for CAD solutions, using 3D graphics applications or a financial wizard working on huge spreadsheets, Philips display will make your images and graphics come alive.
Philips Brilliance P-line 241P6VPJKEB - LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class C
Energy Consumption per Year
63 kWh
Power Consumption (On mode)
43 W
Microphone, 2.0 megapixel camera, USB 3.0 hub
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 at 60 Hz
Pixel Pitch
0.137 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
14 ms (typical); 5 ms (grey-to-grey)
Colour Support
1.074 billion colours (10-bit)
Input Connectors
HDMI, DVI-D, VGA, DisplayPort, MHL
Display Position Adjustments
Textured black
53.1 cm x 25.6 cm x 42.2 cm
5.85 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, ICES-003, SEMKO, TUV Ergo, PSB, DDC/CI, RoHS, Lead-Free, WEEE, PSE Mark, J-MOSS, TCO Certified Edge, E-Standby, KC, CECP, EPA, TCO Displays, cETLus, RCM, Ukrain Safety, CU-EAC
Display Type
Energy Class
Class C
63 kWh
43 W
Diagonal Size
24"
Viewable Size
23.8"
Built-in Devices
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.137 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Picture in picture, ambient light sensor, Sync on Green, PowerSensor, SmartResponse, MultiView, SmartImage, Smart Ergo base, 99% sRGB colour gamut, Flicker Free technology, BFR/PVC-free, Mercury free, PBP
Textured black
53.1 cm x 25.6 cm x 42.2 cm - with stand
5.85 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DisplayPort , DVI-D (HDCP) , VGA , MHL / HDMI , 3 x USB 3.0 , Audio line-in , Headphones
Mechanical
Tilt Angle
-5/+20
Swivel Angle
350
Rotation Angle
90
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
MTBF
70,000 hour(s)
30.11 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
On / Off Switch
No
Included Software
Philips SmartControl Premium
Apple MacOS X, Microsoft Windows 7 / 8 / 8.1
Dimensions & Weight Details
With stand - width: 53.1 cm - depth: 25.6 cm - height: 42.2 cm - weight: 5.85 kg , Without stand - width: 53.1 cm - depth: 5.2 cm - height: 36.3 cm - weight: 3.36 kg
ENERGY STAR Certified
20 - 80%
Accessories
£8.85
C2G HDMI to DisplayPort Adapter Converter
Quicklinx: 9MR6 | In Stock
£39.98
£24.58
£9.80
£18.00
£13.78
Scroll to top
