BT.com
Wishlist
Philips 241P6QPJKES/00 24" 1920x1080 VGA DVI Monitor
Delivery
Standard Due date unavailable
The Philips PowerSensor AH-IPS LED display with Webcam helps you collaborate and communicate, saving you time and money.
Philips Brilliance P-line 241P6QPJKES - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
35 kWh
Power Consumption (On mode)
24 W
Microphone, camera, USB 3.0 hub
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
14 ms (typical); 5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Speakers
Internal
Display Position Adjustments
Textured black, textured silver
53.1 cm x 25.6 cm x 42.2 cm
6.47 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, ICES-003, SEMKO, CCC, TUV Ergo, PSB, DDC/CI, RoHS, Lead-Free, WEEE, PSE Mark, J-MOSS, TCO Certified Edge, E-Standby, KC, CECP, TCO Displays 6.0, cETLus, CU-EAC
Display Type
Energy Class
Class A
35 kWh
24 W
Diagonal Size
24"
Viewable Size
23.8"
Built-in Devices
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, HDCP, Eco-Mode, PowerSensor, SmartResponse, SmartContrast, SmartImage, game mode, Cinema Mode, Mobile High-Definition Link (MHL), Smart Ergo base, SmartConnect, Flicker Safe, Mercury free
53.1 cm x 25.6 cm x 42.2 cm - with stand
6.47 kg
Audio
Speakers - stereo - internal
Output Power / Channel
2 Watt
VGA , DVI-D (HDCP) , HDMI , DisplayPort , 3 x USB 3.0 , Headphones , Audio line-in
Mechanical
Tilt Angle
-5/+20
Swivel Angle
350
Rotation Angle
90
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable , 1 x audio cable , 1 x DisplayPort cable , 1 x USB cable
MTBF
30,000 hour(s)
Power Supply
Internal
18.27 Watt
Power Consumption Stand by
0.3 Watt
On / Off Switch
Included Software
Philips SmartControl Premium
Dimensions & Weight Details
With stand - width: 53.1 cm - depth: 25.6 cm - height: 42.2 cm - weight: 6.47 kg , Without stand - width: 53.1 cm - depth: 5.2 cm - height: 36.3 cm - weight: 3.98 kg
ENERGY STAR Certified
20 - 80%
Accessories
£9.31
C2G HDMI to DisplayPort Adapter Converter
Quicklinx: 9MR6 | In Stock
£42.81
£26.32
£9.80
£21.69
£19.27
£14.77
Scroll to top
