BT.com
Wishlist
Philips 241B6QPYEB/00 24" 1920x1080 DVI VGA Monitor
Delivery
Standard Due date unavailable
The Philips PowerSensor AH-IPS LED display, which uses 65% post-consumer recycled plastics and PVC, BFR-free housing, is ideal for eco-friendly productivity.
What's in the box
  • Monitor with stand
  • Cables
  • User Documentation
Philips Brilliance B-line 241B6QPYEB - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
USB Hub
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Textured black with black stand
53.1 cm x 25.6 cm x 42.2 cm
6.47 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, BSMI, GOST, SASO, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, TCO Certified Edge, TCO Displays 6.0, cETLus
Display Type
Diagonal Size
23.8"
Built-in Devices
USB Hub
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, HDCP, PowerSensor, SmartContrast, SmartImage, WideView, Smart Ergo base, SmartControl Premium, Flicker Free technology, Mercury free
53.1 cm x 25.6 cm x 42.2 cm - with stand
6.47 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
VGA , DVI-D (HDCP) , DisplayPort , 4 x USB 2.0 , Headphones , Audio line-in
Mechanical
Tilt Angle
-5/+20
Swivel Angle
350
Rotation Angle
90
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
MTBF
30,000 hour(s)
Power Supply
Internal
16.73 Watt
Power Consumption Stand by
0.3 Watt
Apple MacOS X, Microsoft Windows 7, Windows 8, Windows 8.1
Dimensions & Weight Details
With stand - width: 53.1 cm - depth: 25.6 cm - height: 42.2 cm - weight: 6.47 kg , Without stand - width: 53.1 cm - depth: 5.2 cm - height: 36.3 cm - weight: 3.98 kg
ENERGY STAR Certified
20 - 80%
Accessories
£11.17
C2G HDMI to DisplayPort Adapter Converter
Quicklinx: 9MR6 | In Stock
£44.95
£27.18
£29.66
£9.80
£27.98
£19.44
£24.90
£19.06
Scroll to top
