BT.com
Wishlist
Philips 24" LED 1920x1200 HD Monitor Black 16:10 1000:1 Speakers
Delivery
Standard Due date unavailable
This Philips PowerSensor LED display with PVC and BFR free housing, USB hub and ergonomic base is ready for eco-friendly productivity.
Philips Brilliance B-line 240B4LPYCB - LED monitor - 24"
LED-backlit LCD monitor - 24"
USB Hub
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
1920 x 1200 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Textured black with black stand
55.5 cm x 22.7 cm x 54.3 cm
5.83 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, UL, TUV GS, BSMI, GOST, cUL, SASO, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, TCO Displays 6.0
3 years warranty
Display Type
Diagonal Size
24"
Built-in Devices
USB Hub
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.27 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
48 - 85 Hz
Horizontal Refresh Rate
24 - 94 kHz
Horizontal Viewing Angle
160
Vertical Viewing Angle
160
Backlight Technology
WLED
OSD Languages
Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish
Sync on Green, sRGB colour management, HDCP, PowerSensor, SmartContrast, SmartImage, Smart Ergo base
55.5 cm x 22.7 cm x 54.3 cm - with stand
5.83 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1.5 Watt
VGA , DVI-D (HDCP) , DisplayPort , 2 x USB 2.0 , Headphones , Audio line-in
Mechanical
Tilt Angle
-5/+20
Swivel Angle
130
Rotation Angle
90
Height Adjustment
110 mm
Flat Panel Mount Interface
100 x 100 mm
MTBF
30,000 hour(s)
Power Supply
Internal
Included Software
Philips SmartControl Premium
Apple MacOS X, Microsoft Windows 7, Microsoft Windows Vista, Windows 8
Dimensions & Weight Details
With stand - width: 55.5 cm - depth: 22.7 cm - height: 54.3 cm - weight: 5.83 kg , Without stand - width: 55.5 cm - depth: 6.5 cm - height: 38.8 cm - weight: 3.97 kg
ENERGY STAR Certified
Limited warranty - 3 years
20 - 80%
Scroll to top
