BT.com
Wishlist
Philips 24" LED 1920 x 1080 HD Monitor 16:9 1000:1 Speakers Black
Delivery
Standard Due date unavailable
This attractive Philips display with slim bezel and AH-IPS screen gives you awesome, vibrant color images. Mobile HD link allows you to mirror your smartphone, immersing you in powerful multimedia.
Philips E-line 244E5QHAD - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class B
Energy Consumption per Year
41 kWh
Power Consumption (On mode)
28 W
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Glossy cherry black
55.7 cm x 21.3 cm x 42.8 cm
3.8 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV, BSMI, GOST, SASO, SEMKO, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE, TCO Displays 6.0, cETLus
3 years warranty
Display Type
Energy Class
Class B
41 kWh
28 W
Diagonal Size
23.8"
Viewable Size
23.8"
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, HDCP, SmartResponse, SmartContrast, TrueVision, Mobile High-Definition Link (MHL)
Glossy cherry black
55.7 cm x 21.3 cm x 42.8 cm - with stand
3.8 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
5 Watt
VGA , 2 x HDMI (HDCP) , Audio line-in , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
MTBF
30,000 hour(s)
Power Supply
External
18.6 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
No
Apple MacOS X, Microsoft Windows 7, Windows 8
Dimensions & Weight Details
With stand - width: 55.7 cm - depth: 21.3 cm - height: 42.8 cm - weight: 3.8 kg , Without stand - width: 55.7 cm - depth: 4.5 cm - height: 33.8 cm - weight: 3.44 kg
ENERGY STAR Certified
Limited warranty - 3 years
20 - 80%
Accessories
£9.99
£6.91
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£18.84
£36.18
£49.00
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£55.62
Scroll to top
