BT.com
Wishlist
Philips 24" Black LCD Monitor Full HD Speakers 130mm Height adj
Philips 24" Black LCD Monitor Full...
£139.99
48 in stock
£139.99
Add to wishlist
Delivery
Standard 1-3 working days
Our S Line monitor delivers business efficiency. A wide-view IPS display with SoftBlue technology is great for easy-on-the-eyes productivity. The height-adjustable, frameless display allows for tiling multiple monitors for an expanded view.
What's in the box
  • Monitor with stand
  • Cables
  • User Documentation
Philips S-line 243S7EHMB - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
29 kWh
Power Consumption (On mode)
20 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Black, textured black
54 cm x 20.2 cm x 48.3 cm
5 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV, ICES-003, SEMKO, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE, CECP, EPA, TCO Displays, cETLus, CU-EAC
Display Type
Energy Class
Class A
29 kWh
20 W
Diagonal Size
24"
Viewable Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Pixel Per Inch
93
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, SmartContrast, SmartImage, Low Blue Light Mode, Flicker Free technology, SoftBlue Technology, EasyRead
54 cm x 20.2 cm x 48.3 cm - with stand
5 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , HDMI , Audio line-in , Headphones
Mechanical
Tilt Angle
-5/+20
Swivel Angle
350
Rotation Angle
90
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable , 1 x HDMI cable , 1 x audio cable
MTBF
70,000 hour(s)
14.6 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Philips SmartControl
Apple MacOS X, Microsoft Windows 7, Windows 8, Windows 8.1, Windows 10
Dimensions & Weight Details
With stand - width: 54 cm - depth: 20.2 cm - height: 48.3 cm - weight: 5 kg , Without stand - width: 54 cm - depth: 4.5 cm - height: 32.5 cm - weight: 3.1 kg
ENERGY STAR Certified
20 - 80%
Scroll to top
