BT.com
Wishlist
Philips 233V5LHAB 23" 1920x1080 5ms VGA HDMI LED Monitor
Delivery
Standard Due date unavailable
Enjoy vivid LED pictures on this Philips display. Equipped with HDMI and stereo speakers, it's a great choice!
Philips V-line 233V5LHAB - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
Energy Class
Class A
Energy Consumption per Year
31 kWh
Power Consumption (On mode)
21 W
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Textured black
54.7 cm x 21.9 cm x 41.6 cm
3.5 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV, BSMI, GOST, SASO, SEMKO, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE, TCO Certified Edge
2 years warranty
Display Type
Energy Class
Class A
31 kWh
21 W
Diagonal Size
23"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (simplified), Ukrainian, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, SmartContrast, SmartControl Lite
Textured black
54.7 cm x 21.9 cm x 41.6 cm - with stand
3.5 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
VGA , HDMI , Audio line-in , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
MTBF
30,000 hour(s)
Power Supply
Internal
AC 120/230 V (50 - 60 Hz)
18.52 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.3 Watt
Apple MacOS X, Microsoft Windows 7, Windows 8
Dimensions & Weight Details
With stand - width: 54.7 cm - depth: 21.9 cm - height: 41.6 cm - weight: 3.5 kg , Without stand - width: 54.7 cm - depth: 5.3 cm - height: 34 cm - weight: 3.13 kg
ENERGY STAR Certified
20 - 80%
Scroll to top
