BT.com
Wishlist
Philips 231P4QPYKEB/00 23" 1920x1080 VGA DVI Monitor
Delivery
Standard Due date unavailable
The Philips IPS LED display with webcam helps you collaborate and communicate, saving you time and money.
Philips Brilliance P-line 231P4QPYKEB - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
USB Hub, 2.0 megapixel camera
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
7 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Textured black with black stand
54.7 cm x 22 cm x 51.5 cm
5.23 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, UL, TUV GS, BSMI, GOST, cUL, SASO, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, TCO Certified Edge, TCO Displays 5.2
Display Type
Diagonal Size
23"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
7 ms (grey-to-grey)
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Controls & Adjustments
Volume
OSD Languages
Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish
Sync on Green, sRGB colour management, HDCP, PowerSensor, SmartResponse, SmartContrast, SmartImage, Smart Ergo base
54.7 cm x 22 cm x 51.5 cm - with stand
5.23 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1.5 Watt
VGA , DVI-D (HDCP) , DisplayPort , 3 x USB 2.0 , Headphones , Audio line-in , Microphone
Mechanical
Tilt Angle
-5/+20
Swivel Angle
130
Rotation Angle
90
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
MTBF
30,000 hour(s)
Power Supply
Internal
29.1 Watt
Power Consumption Stand by / Sleep
0.3 Watt
Included Software
Philips SmartControl Premium
Apple MacOS X, Microsoft Windows Vista / XP / 7
Dimensions & Weight Details
With stand - width: 54.7 cm - depth: 22 cm - height: 51.5 cm - weight: 5.23 kg , Without stand - width: 54.7 cm - depth: 6 cm - height: 34.3 cm - weight: 3.09 kg
ENERGY STAR Certified
20 - 80%
Accessories
£8.31
£9.31
C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL
Quicklinx: 63SL | In Stock
£10.44
£6.00
C2G USB to DVI Adapter Up To 2048 x 1152
Quicklinx: 8H1Y | In Stock
£44.54
C2G 2m HDMI to DVI-D Digital Video Cable
Quicklinx: 915T | In Stock
£8.73
£60.02
Scroll to top
