Click to visit BT.com
BT.com
Wishlist
Philips 23" IPS LED Monitor Black
Quicklinx: 8M84WS00
Mfr#: 234E5QHAB/00
Essential accessories
This attractive Philips display with ultra narrow bezel and AHIPS screen gives you awesome, vibrant color images. Mobile HD link allows you to connect your smartphone.
Philips 234E5QHAB - LED monitor - 23"
LED-backlit LCD monitor - 23"
Energy Class
Class B
Energy Consumption per Year
39 kWh
Power Consumption (On mode)
27 W
Panel Type
AH-IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD 1920 x 1080 at 60 Hz
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Glossy cherry black
53.2 cm x 21.3 cm x 41.4 cm - with stand
3.46 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV, BSMI, GOST, SASO, SEMKO, DDC/CI, RoHS, Lead-Free, ETL, ISO 9241-307, WEEE, TCO Displays 6.0
3 years warranty
Display Type
Energy Class
Class B
39 kWh
27 W
Diagonal Size
23"
Panel Type
AH-IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, HDCP, SmartImage Lite, SmartResponse, SmartContrast, TrueVision, Touch Control, Mobile High-Definition Link (MHL)
Glossy cherry black
3.46 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
6 Watt
VGA , 2 x HDMI ( HDCP ) , Audio line-in , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
MTBF
30,000 hour(s)
Power Supply
External
AC 120/230 V ( 50/60 Hz )
21.9 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.3 Watt
Apple MacOS X, Microsoft Windows 7, Windows 8
Dimensions & Weight Details
With stand - width: 53.2 cm - depth: 21.3 cm - height: 41.4 cm - weight: 3.46 kg , Without stand - width: 53.2 cm - depth: 4.5 cm - height: 32.5 cm - weight: 3.11 kg
Limited warranty - 3 years
20 - 80%
