BT.com
Wishlist
Philips 23" IPS LED Backlight LCD Monitor with MHL Technology
Delivery
Standard Due date unavailable
It experience big entertainment from your mobile device. This Philips display with Mobile HD Link technology enables you to watch HD videos and other content directly from your MHL mobile device while charging it.
The Full HD screen has the widescreen resolution of 1920 x 1080p. This is the high resolution of HD sources for the best possible picture quality. It is fully future-proof as it supports 1080p signals from all sources, including the most recent sources such as Blu-ray and HD game consoles. The signal processing is extensively upgraded to support this much higher signal quality and resolution. It produces brilliant flicker-free progressive scan pictures with superb brightness and colors.
Philips E-line 237E4QHAD - LED monitor - 23"
LED-backlit LCD monitor - 23"
Energy Class
Class B
Energy Consumption per Year
41 kWh
Power Consumption (On mode)
28 W
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
7 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Glossy cherry black
54.7 cm x 19.3 cm x 42 cm
2.82 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, UL, BSMI, GOST, cUL, SASO, SEMKO, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE, TCO Displays 5.2
3 years warranty
Display Type
Energy Class
Class B
41 kWh
28 W
Diagonal Size
23"
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
7 ms (grey-to-grey)
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Controls & Adjustments
Volume
OSD Languages
Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish, Turkish
Sync on Green, power off timer, sRGB colour management, HDCP, SmartResponse, SmartContrast, power on timer, TrueVision, Touch Control
Glossy cherry black
54.7 cm x 19.3 cm x 42 cm - with stand
2.82 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
VGA , HDMI (HDCP)
Mechanical
Tilt
Tilt Angle
-5/+20
MTBF
30,000 hour(s)
Power Supply
External
28.6 Watt
Power Consumption Stand by / Sleep
0.5 Watt
Apple MacOS X, Microsoft Windows Vista / XP / 7
Dimensions & Weight Details
With stand - width: 54.7 cm - depth: 19.3 cm - height: 42 cm - weight: 2.82 kg , Without stand - width: 54.7 cm - depth: 3.7 cm - height: 33.5 cm - weight: 2.52 kg
Limited warranty - 3 years
20 - 80%
Scroll to top
