BT.com
Wishlist
Philips 221S6QUMB/00 22" 1920x1080 USB Monitor
Delivery
Standard Due date unavailable
This notebook docking display enables easy port replication. Expand your viewing workspace, keep peripherals connected, access the Internet, all with a single USB cable to your notebook.
Philips S-line 221S6QUMB - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
USB 2.0 hub
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
14 ms
Colour Support
16.7 million colours
Input Connectors
USB
Speakers
Integrated
Display Position Adjustments
Textured black with black stand
51.1 cm x 22.7 cm x 48.3 cm
4.9 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, VCCI, C-Tick, ICES-003, SEMKO, TUV Ergo, PSB, RoHS, Lead-Free, WEEE, PSE Mark, J-MOSS, E-Standby, KC, CECP, EPA, cETLus, CU-EAC
Display Type
Diagonal Size
22"
Viewable Size
21.5"
Built-in Devices
USB 2.0 hub
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
14 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
sRGB colour management, Smart Ergo base, Flicker Free technology, BFR/PVC-free, Mercury free
51.1 cm x 22.7 cm x 48.3 cm - with stand
4.9 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
3 x USB 2.0 , USB 2.0 upstream
Mechanical
Tilt Angle
-5/+20
Swivel Angle
150
Rotation Angle
90
Height Adjustment
110 mm
Flat Panel Mount Interface
100 x 100 mm
MTBF
70,000 hour(s)
Power Supply
Internal
20 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Windows 8
Dimensions & Weight Details
With stand - width: 51.1 cm - depth: 22.7 cm - height: 48.3 cm - weight: 4.9 kg , Without stand - width: 51.1 cm - depth: 5.2 cm - height: 31.9 cm - weight: 3.1 kg
ENERGY STAR Certified
20 - 80%
Scroll to top
