BT.com
Wishlist
Philips 22" Brilliance LED LCD Monitor S-Line SmartImage Black
Clearance
Last Few Remaining
Price Drop
Price Drop!
Delivery
Standard Due date unavailable
The Philips ergonomic LED display using 25% recycled materials and PVC, BFR free housing is ideal for Eco-friendly productivity.
White LED's are solid state devices which light up to full, consistent brightness faster saving startup time. LED's are free from mercury content which allows for Eco-friendly recycling and disposal process. LED's allow for better dimming control of LCD backlight, resulting in super high contrast ratio. It also gives superior color reproduction thanks to consistent brightness across the screen.
Philips S-line 220S4LCB - LED monitor - 22"
LED-backlit LCD monitor - 22"
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
1680 x 1050 at 60 Hz
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Textured black with black stand
50.4 cm x 22.7 cm x 50.9 cm
5.2 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Plug and Play, FCC Class B certified, UL, TUV GS, BSMI, GOST, cUL, SASO, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, TCO Displays 5.2
3 years warranty
Display Type
Diagonal Size
22"
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast
OSD Languages
Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish
Sync on Green, sRGB colour management, HDCP, Eco-Mode, SmartContrast, SmartImage, TrueVision, SmartPower, Touch Control, Smart Ergo base
50.4 cm x 22.7 cm x 50.9 cm - with stand
5.2 kg
VGA , DVI-D (HDCP)
Mechanical
Tilt Angle
-5/+20
Swivel Angle
130
Rotation Angle
90
Height Adjustment
110 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable
MTBF
30,000 hour(s)
Power Supply
Internal
15.7 Watt
Power Consumption Stand by / Sleep
0.1 Watt
Included Software
Philips SmartControl Premium
Apple MacOS X, Microsoft Windows Vista / XP / 7
Dimensions & Weight Details
With stand - width: 50.4 cm - depth: 22.7 cm - height: 50.9 cm - weight: 5.2 kg , Without stand - width: 50.4 cm - depth: 5.9 cm - height: 34.9 cm - weight: 3.38 kg
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - 3 years
20 - 80%
Accessories
£7.95
£8.90
£12.18
C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL
Quicklinx: 63SL | In Stock
£9.94
£6.00
£8.53
C2G 2m HDMI to DVI-D Digital Video Cable
Quicklinx: 915T | In Stock
£8.43
£56.40
Scroll to top
