BT.com
Wishlist
Philips 22" Brilliance LED backlight LCD Monitor PowerSensor Black
Delivery
Standard Due date unavailable
The Philips PowerSensor LED display using 65% post consumer recycled plastics and PVC, BFR free housing is ideal for eco-friendly productivity.
Philips Brilliance B-line 220B4LPCB - LED monitor - 22"
LED-backlit LCD monitor - 22"
USB Hub
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
1680 x 1050 at 60 Hz
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Textured black with black stand
50.4 cm x 22.7 cm x 50.9 cm
5.2 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Plug and Play, FCC Class B certified, UL, TUV GS, BSMI, GOST, cUL, SASO, SEMKO, TUV Ergo, DDC/CI, RoHS, WEEE, TCO Displays 5.2
3 years warranty
Display Type
Diagonal Size
22"
Built-in Devices
USB Hub
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
Controls & Adjustments
Volume, brightness
OSD Languages
Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish
Sync on Green, sRGB colour management, HDCP, PowerSensor, SmartContrast, SmartImage, Smart Ergo base
50.4 cm x 22.7 cm x 50.9 cm - with stand
5.2 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1.5 Watt
VGA , DVI-D , Audio line-in/out , 2 x USB 2.0
Mechanical
Tilt Angle
-5/+20
Swivel Angle
130
Rotation Angle
90
Height Adjustment
110 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable
MTBF
30,000 hour(s)
Power Supply
Internal
AC 120/230 V (50 - 60 Hz)
15.8 Watt
Power Consumption Stand by / Sleep
0.3 Watt
Apple MacOS X, Microsoft Windows Vista / XP / 7
Dimensions & Weight Details
With stand - width: 50.4 cm - depth: 22.7 cm - height: 50.9 cm - weight: 5.2 kg , Without stand - width: 50.4 cm - depth: 5.9 cm - height: 34.9 cm - weight: 3.38 kg
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - 3 years
20 - 80%
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.68
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.23
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£20.60
£14.40
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£30.90
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£18.55
Scroll to top
