BT.com
Wishlist
Philips 21.5" Brilliance LED Monitor S-Line with SmartImage Black
Delivery
Standard Due date unavailable
With features like Ergo base, 0.1watt Soft off mode, Dual inputs, SmartImage and SmartControl, the energy efficient Philips 221S3 increases your productivity.
Philips Brilliance S-line 221S3LCB - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Height, swivel, tilt
50.7 cm x 22 cm x 40 cm
4.8 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, UL, TUV GS, BSMI, GOST, cUL, SEMKO, TUV Ergo, DDC/CI, RoHS, halogen-free, TCO Displays 5.1
3 years warranty
Display Type
Diagonal Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
176
Vertical Viewing Angle
170
Backlight Technology
WLED
Controls & Adjustments
Brightness
OSD Languages
Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish
Sync on Green, sRGB colour management, HDCP, Eco-Mode, SmartContrast, SmartImage, SmartPower, Touch Control
50.7 cm x 22 cm x 40 cm - with stand
4.8 kg
VGA , DVI-D
Mechanical
Tilt Angle
-5/+20
Swivel Angle
130
Height Adjustment
70 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable
MTBF
30,000 hour(s)
Power Supply
Internal
16.8 Watt
Power Consumption Stand by / Sleep
0.1 Watt
Included Software
Philips SmartControl
Apple MacOS X, Microsoft Windows Vista / XP / 7
Dimensions & Weight Details
With stand - width: 50.7 cm - depth: 22 cm - height: 40 cm - weight: 4.8 kg , Without stand - width: 50.7 cm - depth: 5.9 cm - height: 32.3 cm - weight: 3.5 kg
ENERGY STAR Certified
Limited warranty - 3 years
20 - 80%
Accessories
£7.96
£8.85
£12.16
C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL
Quicklinx: 63SL | In Stock
£9.90
£6.00
C2G USB to DVI Adapter Up To 2048 x 1152
Quicklinx: 8H1Y | In Stock
£41.59
C2G 2m HDMI to DVI-D Digital Video Cable
Quicklinx: 915T | In Stock
£8.38
£56.05
Scroll to top
