BT.com
Wishlist
Philips 21.5" Brilliance LED backlight LCD monitor PowerSensor Silve
Delivery
Standard Due date unavailable
Eco-friendly, EPEAT Gold certified Philips Business Line 221B3 LED display with intelligent PowerSensor detects user presence and adjusts power consumption saving up to 80% of energy bills! PowerSensor is a built-in 'people sensor' that transmits and receives harmless infrared signals to determine if user is present and automatically reduces monitor brightness when user steps away from the desk, cutting energy costs by up to 80-percent and prolonging monitor life. Philips' monitor with LED backlighting is free of mercury content, one of the most toxic natural substances which affect humans and animals. This allows for an eco-friendly display throughout its lifecycle, from manufacturing to disposal.
Philips Brilliance B-line 221B3LPCS - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
USB Hub
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Textured silver
50.7 cm x 22.7 cm x 48 cm
5.3 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, UL, TUV GS, BSMI, GOST, cUL, SEMKO, TUV Ergo, DDC/CI, RoHS, TCO Displays 5.1
3 years warranty
Display Type
Diagonal Size
21.5"
Built-in Devices
USB Hub
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
176
Vertical Viewing Angle
170
Backlight Technology
WLED
Controls & Adjustments
Volume
OSD Languages
Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish
Sync on Green, sRGB colour management, Compact Ergo Base, HDCP, Super Ergo base, PowerSensor, SmartTouch, SmartContrast, SmartImage
Textured silver
50.7 cm x 22.7 cm x 48 cm - with stand
5.3 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1.5 Watt
VGA , DVI-D (HDCP) , Headphones , 2 x USB , Audio line-in
Mechanical
Tilt Angle
-5/+20
Swivel Angle
130
Height Adjustment
110 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable
MTBF
30,000 hour(s)
Power Supply
Internal
17.8 Watt
Power Consumption Stand by / Sleep
0.1 Watt
Dimensions & Weight Details
With stand - width: 50.7 cm - depth: 22.7 cm - height: 48 cm - weight: 5.3 kg , Without stand - width: 50.7 cm - depth: 5.9 cm - height: 32.3 cm - weight: 3.4 kg
ENERGY STAR Certified
Limited warranty - 3 years
20 - 80%
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.62
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.30
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£19.63
£13.69
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£30.54
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£17.96
Scroll to top
