BT.com
Wishlist
Philips 20" LED 1600 x 900 Monitor 16:9 600:1 Black Bezel
Delivery
Standard Due date unavailable
The Philips ergonomic LED display using PVC-BFR free housing is ideal for eco-friendly productivity.
Philips S-line 200S4LMB - LED monitor - 20"
LED-backlit LCD monitor - 20"
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Textured black with black stand
47.9 cm x 22.7 cm x 29.9 cm
4.2 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
Plug and Play, FCC Class B certified, GOST, GS, SASO, SEMKO, DDC/CI, RoHS, Lead-Free, WEEE, TCO Displays 6.0, EAC, cETLus
Display Type
Diagonal Size
20"
Viewable Size
19.5"
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
Controls & Adjustments
Brightness
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, HDCP, Eco-Mode, SmartContrast, SmartImage, TrueVision, Smart Ergo base
47.9 cm x 22.7 cm x 29.9 cm - with stand
4.2 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
VGA , DVI-D (HDCP) , Audio line-in
Mechanical
Tilt Angle
-5/+20
Swivel Angle
130
Rotation Angle
90
Height Adjustment
110 mm
Flat Panel Mount Interface
100 x 100 mm
MTBF
30,000 hour(s)
Power Supply
Internal
13.01 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Philips SmartControl Premium
Apple MacOS X, Microsoft Windows 7, Microsoft Windows Vista, Windows 8
Dimensions & Weight Details
With stand - width: 47.9 cm - depth: 22.7 cm - height: 29.9 cm - weight: 4.2 kg , Without stand - width: 47.9 cm - depth: 4.8 cm - height: 29.9 cm - weight: 1.87 kg
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
20 - 80%
Accessories
£8.41
£9.42
C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL
Quicklinx: 63SL | In Stock
£10.56
£6.00
C2G USB to DVI Adapter Up To 2048 x 1152
Quicklinx: 8H1Y | In Stock
£44.74
C2G 2m HDMI to DVI-D Digital Video Cable
Quicklinx: 915T | In Stock
£8.92
£60.32
Scroll to top
