Click to visit BT.com
BT.com
Wishlist
Philips 19S4LAB/00 19" 1280 x 1024 VGA DVI LED Monitor
Quicklinx: 89FTWS00
Mfr#: 19S4LAB/00
The Philips LED display using 25% recycled materials and PVC, BFR free housing is ideal for eco-friendly productivity.
Philips S-line 19S4LAB - LED monitor - 19"
LED-backlit LCD monitor - 19"
Built-in Devices
Stereo speakers
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 60 Hz
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
40.4 cm x 18.8 cm x 41.9 cm - with stand
3.8 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
Plug and Play, FCC Class B certified, UL, TUV GS, BSMI, GOST, cUL, SASO, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, TCO Displays 5.2
Display Type
Diagonal Size
19"
Built-in Devices
Stereo speakers
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
OSD Languages
Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish
Sync on Green, sRGB colour management, HDCP, SmartImage, TrueVision, SmartPower
3.8 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1.5 Watt
VGA , DVI-D , Audio line-in , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
MTBF
30,000 hour(s)
Power Supply
Internal
AC 120/230 V ( 50/60 Hz )
18.48 Watt
Power Consumption Stand by / Sleep
0.1 Watt
Apple MacOS X, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
Dimensions & Weight Details
With stand - width: 40.4 cm - depth: 18.8 cm - height: 41.9 cm - weight: 3.8 kg , Without stand - width: 40.4 cm - depth: 5.5 cm - height: 34.7 cm - weight: 3.1 kg
EPEAT Compliant
EPEAT Silver
20 - 80%
