BT.com
Wishlist
Peerless-AV Wall Mount 25-60" with PC Holder (51x378x229mm max)
Peerless-AV Wall Mount 25-60" with...
£115.12
£115.12
Add to wishlist
Delivery
Standard 1-3 working days
Designed to wall mount smaller computers, the DS509 is a low-profile universal solution for digital signage applications. Its bottom disengaging design allows the screen to have a negative tilt that enables quick and easy computer maintenance without having to remove the screen. Engineered for strength, durability and easy installation this mount offers VESA compliance and is compatible with Peerless PLP adapter plate technology to accommodate any flat panel display.
Peerless Custom Slim Tilt Mount with PC Holder DS509 - mounting kit
Mounting kit - on-wall mounted
Mounting Components
Wall bracket
7 cm x 26.1 cm x 46.4 cm
Adjustments
Tilt
6 kg
Recommended Use
LCD display / CPU
Recommended Display Size
25" - 60"
Flat Panel Mount Interface
100 x 100 mm, 100 x 200 mm, 200 x 200 mm
Max Load Weight
91 kg
7 cm
26.1 cm
46.4 cm
6 kg
AV Furniture
Mounting kit
Mounting Components
Wall bracket
Recommended Use
LCD display / CPU
Placing / Mounting
On-wall mounted
25" - 60"
Adjustments
Tilt
Max Load Weight
91 kg
Scroll to top
