BT.com
Wishlist
Peerless-AV Video Wall Ceiling Mount for 2x2 Configs for 40-55" Displays
Peerless-AV Video Wall Ceiling...
£1,558.11
£1,558.11
Add to wishlist
Delivery
Standard Due date unavailable
Video wall displays no longer need to be limited to just walls and carts. With the Peerless-AV DS-VWT955-2X2, a video wall display can now be mounted to a ceiling. The tool-less micro adjustable design provides placement of four displays in a 2 x 2 configuration, neatly aligned on the same plane. The tilting adjustment options of 5, 10, 15 and 20 degrees means you can be assured of the perfect viewing angle for your application. It is ideal for department stores, entertainment venues or other large public areas. Compatible with Peerless-AV fixed length and adjustable length columns.
Peerless Digital Signage Video Ceiling Mount DS-VWT955-2X2 - ceiling mount
Ceiling mount
Recommended Use
4 LCD / plasma panels
Recommended Display Size
40"-50"
Flat Panel Mount Interface
200 x 200 mm, 600 x 400 mm
AV Furniture
Ceiling mount
Mounting Components
Ceiling mount
Recommended Use
40"-50"
Adjustments
Tilt
Adjustable height, adjustable width
Scroll to top
