BT.com
Wishlist
Peerless-AV Video Conference Cart w/Metal Shelf for Two 40" to 55"
Peerless-AV Video Conference Cart...
£1,047.04
Hurry, only 3 left in stock!
£1,047.04
Add to wishlist
Delivery
Standard 1-3 working days
The SR555M Video Conference TV Cart has been designed to include all of the features you may need, making it perfect for any location. The mobility of the cart eliminates the need for multiple video conference systems, lowering your overall system cost. The structure is optimized to hold two 40"-55" TVs, providing clear visibility for all participants. The camera locates anywhere above either display, for near perfect eye contact during your meetings. Additionally, the integrated cable management contains and conceals unsightly cables, helping you complete a clean and professional installation.
Peerless SmartMount SR555M - cart
Cart
Mounting Components
Shelf, cart base, column, 4 casters, dual displays mount, camera shelf
178.4 cm x 73.7 cm x 198.3 cm
Tilt
-5°
Adjustments
Yaw
40.9 kg
Recommended Use
Video conferencing system
Recommended Display Size
40"-55"
Flat Panel Mount Interface
200 x 200 mm, up to 400 x 400 mm
Material
Powder-coated metal, powder-coated aluminium
Wheels Qty
4
5 years warranty
178.4 cm
73.7 cm
198.3 cm
40.9 kg
Material
AV Furniture
Cart
Mounting Components
Recommended Use
Cable Management
Integrated cable management
40"-55"
Tilt
-5°
Adjustments
Yaw
Wheels Qty
4
Wheel Diameter
10.2 cm
Brakes Qty
2
Adjustable height, metal shelf
Dimensions & Weight Details
UL, cUL, Directive 2002/95/EC
Limited warranty - 5 years
Scroll to top
