BT.com
Wishlist
Peerless-AV VESA V200x200 Adaptor from V100
Peerless-AV VESA V200x200 Adaptor...
£17.50
4 in stock
£17.50
Add to wishlist
Delivery
Standard 3-5 working days
The Peerless Modular Series has been introduced as a mounting system with just over a dozen components that combine to meet virtually any installation application.
Peerless Modular Series - mounting component
Mounting component
Mounting Components
Mounting adapter
22.2 cm 23.7 cm
Recommended Use
LCD / plasma panel
Recommended Display Size
Up to 37"
Flat Panel Mount Interface
200 x 200 mm, 200 x 100 mm
Max Load Weight
30 kg
22.2 cm
23.7 cm
AV Furniture
Mounting component
Mounting Components
Mounting adapter
Recommended Use
LCD / plasma panel
Up to 37"
Max Load Weight
30 kg
Scroll to top
