BT.com
Wishlist
Peerless-AV VESA 800x400mm Adaptor Bracket
Delivery
Standard Due date unavailable
Increase your mounts' compatibility with the ACC-DSVW8X4 by Peerless-AV. This low cost adapter rail solution for displays with VESA 800 x 400 mm mounting patterns allows the display to be mounted with the video wall mounts. In addition, keeping the adapter rails located near the corners of the display allows the mount to independently fine tune each corner for precision alignment, giving your video wall a seamless appearance.
Peerless-AV ACC-DSVW8X4 - mounting component
Mounting component
Mounting Components
Bracket adapter
9.9 cm x 1.3 cm x 43.2 cm
1 kg
Recommended Use
LCD display
Flat Panel Mount Interface
800 x 400 mm
Max Load Weight
57 kg
Black powder coat
5 years warranty
9.9 cm
1.3 cm
43.2 cm
1 kg
Black powder coat
AV Furniture
Mounting component
Mounting Components
Bracket adapter
Recommended Use
LCD display
800 x 400 mm
Max Load Weight
57 kg
Limited warranty - 5 years
Scroll to top
