BT.com
Wishlist
Peerless-AV VESA 600x800 Adaptor
£54.27
£54.27
Add to wishlist
Delivery
Standard Due date unavailable
Increase your mounts' compatibility with the ACC-V800X by Peerless -AV. This low cost adapter rail solution for displays with VESA 600 x 400 or 800 x 400 mm mounting patterns allows the display to be mounted in either landscape or portrait orientation by attaching to the mount at the 400 x 400 mm pattern.
Peerless ACC-V800X - mounting component
Mounting component - wall-mountable
Mounting Components
2 VESA adapters
90.2 cm x 1.3 cm x 2.5 cm
1.4 kg
Recommended Use
LCD / plasma panel
Recommended Display Size
40"-65"
Flat Panel Mount Interface
400 x 400 mm, 800 x 400 mm, 600 x 400 mm
Max Load Weight
59 kg
Black powder coat
5 years warranty
90.2 cm
1.3 cm
2.5 cm
1.4 kg
Black powder coat
AV Furniture
Mounting component
Mounting Components
2 VESA adapters
Recommended Use
LCD / plasma panel
Placing / Mounting
Wall-mountable
40"-65"
Max Load Weight
59 kg
Anti-theft
Scroll to top
