BT.com
Wishlist
Peerless-AV Universal Ultra Slim Articulating Wall Mount 37 - 65"
Peerless-AV Universal Ultra Slim...
£208.66
12 in stock
£208.66
Add to wishlist
Delivery
Standard 1-3 working days
The Peerless-AV DesignerSeries universal ultra slim articulating wall mount is designed exclusively for ultra-thin displays. The SUA761PU is built to hold medium to larger displays firmly in any position - landscape or portrait - while still offering an ultra-low profile. An innovative i-shaped adaptor plate makes it easy to access the back of the display, keeping hardware hidden, and features internal cable management, providing a clean, professional look that transitions smoothly from the wall to the display.
Peerless-AV Designer Series SUA761PU - wall mount
Wall mount
61.9 cm 43 cm
Adjustable Depth
4.7-63.1 cm
Tilt
-5° to 15°
Rotation
-90° to 90°
Recommended Use
LCD / plasma panel
Recommended Display Size
37"-65"
Flat Panel Mount Interface
200 x 200 mm, 400 x 300 mm, 400 x 200 mm, 400 x 400 mm, 600 x 400 mm, 300 x 200 mm, 200 x 100 mm, 300 x 300 mm
Max Load Weight
36 kg
Black glossy finish
61.9 cm
43 cm
Adjustable Depth
4.7-63.1 cm
Black glossy finish
AV Furniture
Wall mount
Mounting Components
Articulating wall mount
Recommended Use
LCD / plasma panel
Cable Management
Integrated cable management
37"-65"
Tilt
-5° to 15°
Rotation
-90° to 90°
Adjustments
Roll, levelling, tilt
Max Load Weight
36 kg
Scroll to top
