BT.com
Wishlist
Peerless-AV Universal Tilt Wall Mount for 39" to 80" Displays
Peerless-AV Universal Tilt Wall...
£75.99
5 in stock
£75.99
Add to wishlist
Delivery
Standard 3-5 working days
Ideally suited for extra large LCD and Plasma screens, the Paramount PT660 tilting mount allows you to mount your LCD/Plasma screen quickly and easily and tilt it forward/back for an improved viewing angle.
Peerless PARAMOUNT Universal Tilt Wall Mount PT660 - mounting kit
Mounting kit
Mounting Components
Wall plate, tilt bracket
Tilt
4.4 kg
Recommended Use
LCD / plasma panel
Recommended Display Size
39"-80"
Max Load Weight
90.8 kg
Material
Cold-rolled steel
Gloss black
5 years warranty
78.1 cm
6.3 cm
47 cm
4.4 kg
Material
Cold-rolled steel
Gloss black
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD / plasma panel
Max Mounting Pattern Size
738 x 449 mm
39"-80"
Tilt
Max Load Weight
90.8 kg
Sorted-For-You, scratch-resistant
Limited warranty - 5 years
Scroll to top
