Ideally suited for medium/large LCD screens, the Paramount PT640 tilting mount allows you to mount your LCD screen quickly and easily and tilt it forward/back for an improved viewing angle.
Peerless PARAMOUNT Universal Tilt Wall Mount PT640 - mounting kit
Mounting kit
Mounting Components
Fasteners, tilt wall plate
48.9 cm x 6.4 cm x 34.9 cm
Tilt
3 kg
Recommended Use
LCD display
Recommended Display Size
32"-40"
Max Load Weight
68 kg
Material
Fused epoxy
Gloss black
5 years warranty
48.9 cm
6.4 cm
34.9 cm
3 kg
Material
Fused epoxy
Gloss black
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD display
32"-40"
Tilt
Max Load Weight
68 kg
Sorted-For-You
Limited warranty - 5 years
