BT.com
Wishlist
Peerless-AV Universal Tilt Wall Mount For 22" to 40" Displays
Peerless-AV Universal Tilt Wall...
£25.11
33 in stock
£25.11
Add to wishlist
Delivery
Standard 3-5 working days
Ideally suited for medium (22-40") LCD screens, the Paramount PT632 tilting wall mount allows you to mount your LCD screen quickly and easily and tilt it forward/back for an improved viewing angle.
Peerless PARAMOUNT Tilting Wall Mount PT632 - mounting kit
Mounting kit
Mounting Components
Wall plate, mounting adapter, mounting plate
22.2 cm 22.2 cm
Adjustable Depth
5.1-9.6 cm
Tilt
-5° to 15°
0.8 kg
Recommended Use
LCD TV
Recommended Display Size
22"-40"
Flat Panel Mount Interface
100 x 100 mm, 200 x 200 mm, 200 x 100 mm
Max Load Weight
36 kg
Material
Steel
Gloss black
22.2 cm
22.2 cm
Adjustable Depth
5.1-9.6 cm
0.8 kg
Material
Steel
Gloss black
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD TV
22"-40"
Tilt
-5° to 15°
Max Load Weight
36 kg
Scratch-resistant, Hook-and-Hang
Scroll to top
