BT.com
Wishlist
Peerless-AV Universal Tilt Wall Mount For 10" to 24" Displays
Peerless-AV Universal Tilt Wall...
£16.35
15 in stock
£16.35
Add to wishlist
Delivery
Standard 3-5 working days
Ideally suited for small (10-24") LCD screens, the Paramount PT630 tilting wall mount allows you to mount your LCD screen quickly and easily and tilt it forward/back for an improved viewing angle.
Peerless PARAMOUNT Universal Tilt Wall Mount PT630 - mounting kit
Mounting kit
Mounting Components
Wall plate, mounting plate
12.1 cm x 5.7 cm x 12.1 cm
Tilt
0.57 kg
Recommended Use
LCD TV
Recommended Display Size
10"-24"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
36.2 kg
Material
Steel
Gloss black
5 years warranty
12.1 cm
5.7 cm
12.1 cm
0.57 kg
Material
Steel
Gloss black
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD TV
10"-24"
Tilt
Max Load Weight
36.2 kg
Scratch-resistant
Limited warranty - 5 years
Scroll to top
