BT.com
Wishlist
Peerless-AV Universal Pivot Wall Mount For 22-40" Displays
Peerless-AV Universal Pivot Wall...
£50.47
£50.47
Add to wishlist
Delivery
Standard Due date unavailable
Ideally suited for medium LCD screens, the Paramount PP740 pivoting wall mount gives you a wide range of screen adjustment to obtain a better viewing angle. The PP740 allows you to tilt your screen forward or back, pan left or right and even extend your flat panel screen away from the wall.
Peerless PARAMOUNT Pivot Wall Mount PP740 - mounting kit (Tilt & Swivel)
Mounting kit (Tilt & Swivel)
Mounting Components
Wall arm, mounting adapter
23.6 cm
Adjustable Width
22.2-26 cm
Adjustable Depth
7.5-20.6 cm
1.7 kg
Recommended Use
LCD TV
Recommended Display Size
22"-40"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 200 x 100 mm
Max Load Weight
36.2 kg
Material
Steel, anodised aluminium
High-gloss black
5 years warranty
23.6 cm
Adjustable Width
22.2-26 cm
Adjustable Depth
7.5-20.6 cm
1.7 kg
Material
High-gloss black
AV Furniture
Mounting kit
Mounting Components
Design
Tilt & Swivel
Recommended Use
LCD TV
22"-40"
Max Load Weight
36.2 kg
Scratch-resistant
Limited warranty - 5 years
Scroll to top
