BT.com
Wishlist
Peerless-AV Universal Outdoor Tilt Wall Mount
Peerless-AV Universal Outdoor Tilt...
£172.83
£172.83
Add to wishlist
Delivery
Standard Due date unavailable
Peerless' outdoor universal wall mount provides a sure way to mount flat panels outdoors with its corrosion resistant E-Coat and stainless steel hardware that is resistant to corrosion when exposed to the elements. In addition to simple installation with its hook-and-hang design, this mount offers tilt functionality while keeping the flat panel screen a mere 2.58" from the wall. Tamper-resistant hardware deters theft, offering a peace-of-mind with every installation.
Peerless Universal EPT650 - mounting kit
Mounting kit
Mounting Components
Wall plate
78.1 cm x 6.6 cm x 47 cm
Adjustments
Tilt
4 kg
Recommended Use
LCD / plasma panel
Recommended Display Size
32"-55"
Flat Panel Mount Interface
600 x 400 mm
Max Mounting Pattern Size
738 x 449 mm
Max Load Weight
79 kg
Material
Stainless steel
5 years warranty
78.1 cm
6.6 cm
47 cm
4 kg
Material
Stainless steel
AV Furniture
Mounting kit
Mounting Components
Wall plate
Recommended Use
LCD / plasma panel
Indoor / Outdoor
Indoor, outdoor
600 x 400 mm
738 x 449 mm
Cable Management
Integrated cable management
32"-55"
Adjustments
Tilt
Max Load Weight
79 kg
Horizontal shift
Limited warranty - 5 years
Scroll to top
