BT.com
Wishlist
Peerless-AV Universal Flat Wall Mount for 39" to 80" Displays
Peerless-AV Universal Flat Wall...
£58.42
More than 50 in stock
£58.42
Add to wishlist
Delivery
Standard 3-5 working days
Ideally suited for extra large LCD and plasma screens, the Paramount PF660 flat-to-wall mount allows you to mount your LCD/plasma screen quickly and easily. The low profile design holds the screen only 43mm away from the wall.
Peerless PARAMOUNT Universal Flat Wall Mount PF660 - mounting kit
Mounting kit
Mounting Components
Wall plate, bracket adapter
78.1 cm x 4.3 cm x 45.7 cm
3.5 kg
Recommended Use
LCD / plasma panel
Recommended Display Size
39"-90"
Max Mounting Pattern Size
825 x 450 mm
Max Load Weight
90.8 kg
Material
Cold-rolled steel
Gloss black
5 years warranty
78.1 cm
4.3 cm
45.7 cm
3.5 kg
Material
Cold-rolled steel
Gloss black
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD / plasma panel
825 x 450 mm
39"-90"
Max Load Weight
90.8 kg
Scratch-resistant
Limited warranty - 5 years
Scroll to top
