BT.com
Wishlist
Peerless-AV Universal Flat Wall Mount For 10" to 24" Displays
Peerless-AV Universal Flat Wall...
£14.79
More than 50 in stock
£14.79
Add to wishlist
Delivery
Standard 3-5 working days
Ideally suited for small (10-2") LCD screens, the Paramount PF630 flat-to-wall mount allows you to mount your LCD screen quickly and easily. The low profile design holds the screen only 17mm away from the wall.
Peerless PARAMOUNT Universal Flat Wall Mount PF630 - mounting kit
Mounting kit
Mounting Components
Wall plate, mounting adapter
14.2 cm x 1.7 cm x 12.7 cm
0.58 kg
Recommended Use
LCD TV
Recommended Display Size
10"-24"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
36.2 kg
Gloss black
5 years warranty
14.2 cm
1.7 cm
12.7 cm
0.58 kg
Gloss black
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD TV
10"-24"
Max Load Weight
36.2 kg
Scratch-resistant
Limited warranty - 5 years
Scroll to top
