BT.com
Wishlist
Peerless-AV Universal Articulating Wall Mount
For 22" to 40" Displays
Peerless-AV Universal Articulating...
£74.79
Peerless-AV Universal Articulating Wall Mount For 22" to 40" Displays
11 in stock
£74.79
Add to wishlist
Delivery
Standard 3-5 working days
It's easy to get the best viewing position when you can effortlessly pull out the display from the wall, position it in almost any direction, even turn it around corners and then smoothly return it to the wall when finished. Level the display at any time, even after installation, for that picture perfect end result. Never worry about cables and cords getting in the way; cable management delivers a clean clutter-free look to any installation.
Peerless PARAMOUNT Articulating Wall Mount PA740 - mounting kit (Tilt & Swivel)
Mounting kit (Tilt & Swivel) - wall-mountable
Mounting Components
Articulating arm, adapter plate, hook bracket
23.9 cm 22.2 cm
Adjustable Depth
7.1-37.9 cm
Tilt
-5° to 15°
Rotation
-90° to 90°
2.04 kg
Recommended Use
LCD / plasma panel
Recommended Display Size
22"-40"
Flat Panel Mount Interface
100 x 100 mm, 200 x 200 mm, 200 x 100 mm
Max Load Weight
36 kg
Gloss black
23.9 cm
22.2 cm
Adjustable Depth
7.1-37.9 cm
2.04 kg
Gloss black
AV Furniture
Mounting kit
Mounting Components
Design
Tilt & Swivel
Recommended Use
LCD / plasma panel
Placing / Mounting
Wall-mountable
Cable Management
Integrated cable management
22"-40"
Tilt
-5° to 15°
Rotation
-90° to 90°
Max Load Weight
36 kg
Scratch-resistant, swivel adjustment, Hook-and-Hang
Scroll to top
