BT.com
Wishlist
Peerless-AV Universal Articulating Wall Mount
For 10"-29" Displays
Peerless-AV Universal Articulating...
£44.86
Peerless-AV Universal Articulating Wall Mount For 10"-29" Displays
15 in stock
£44.86
Add to wishlist
Delivery
Standard 3-5 working days
The Paramount™ series wall mounts provide versatile and multi-functional features. With PA730, extend the display up to 14.85" (377mm) or fully-retract it to just 2.73" (69mm) from the wall for for the perfect viewing angle. The Hook-and-Hang™ system offers easy, one-person installation of the display. One-Touch™ tilt technology offers ±15° vertical tilt movement for the ideal viewing angle. Integrated cable management protects, contains and conceals cables for a clean installation.
  • Extends 14.85" (377mm) from the wall
  • Retracts to 2.73" (69mm) to save space
  • One-Touch tilt mechanism offers ±15° of tilt angle adjustment
  • ±5° of roll for post installation display leveling
  • ±90° of pivot
  • VESA® 75 and 100mm compliant
  • Design is UL listed and tested to four times stated load capacity
Peerless Universal Full-Motion Plus Wall Mount PA730 - mounting kit (Tilt & Swivel)
Mounting kit (Tilt & Swivel) - wall-mountable
Mounting Components
Articulating arm, mounting adapter
14 cm
Adjustable Width
11.9-22.8 cm
Adjustable Depth
3.1-36.7 cm
Tilt
1.5 kg
Recommended Use
LCD TV
Recommended Display Size
10"-29"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
11.3 kg
Material
Steel, anodised aluminium
High-gloss black
5 years warranty
Casio EV-1000
14 cm
Adjustable Width
11.9-22.8 cm
Adjustable Depth
3.1-36.7 cm
1.5 kg
Material
High-gloss black
AV Furniture
Mounting kit
Mounting Components
Design
Tilt & Swivel
Recommended Use
LCD TV
Placing / Mounting
Wall-mountable
10"-29"
Tilt
Max Load Weight
11.3 kg
Scratch-resistant, swivel adjustment
Limited warranty - 5 years
Casio EV-1000
Scroll to top
