BT.com
Wishlist
Peerless-AV Ultra-Slim Universal Tilt Wall Mount for 37-60" Displays
Peerless-AV Ultra-Slim Universal...
£146.56
£146.56
Add to wishlist
Delivery
Standard Due date unavailable
Ultra Slim is the world's thinnest tilting mounting solution at less that 1.7cm - yes that's only 17mm! - making it almost invisible once installed. Designed for the next generation of super slim LCD & LED panels this product is a step ahead of anything else available in the market. Own the most discrete wall mount ever developed with the Ultra Slim range from Peerless.
Peerless Slimline Universal Ultra-thin Tilt Wall Mount SUT660P - wall mount
Wall mount
93.3 cm x 1.7 cm x 43.8 cm
Tilt
5.2 kg
Recommended Use
LCD / plasma panel
Recommended Display Size
37"-60"
Flat Panel Mount Interface
800 x 400 mm
Max Load Weight
45 kg
Material
Cold-rolled steel
Gloss black
93.3 cm
1.7 cm
43.8 cm
5.2 kg
Material
Cold-rolled steel
Gloss black
AV Furniture
Wall mount
Mounting Components
Wall mount
Recommended Use
LCD / plasma panel
800 x 400 mm
37"-60"
Tilt
Max Load Weight
45 kg
Adjustable depth, scratch-resistant, horizontal shift
Scroll to top
