BT.com
Wishlist
Peerless-AV Ultra-Slim Universal Flat Wall Mount for 37-65" Displays
Peerless-AV Ultra-Slim Universal...
£95.40
1 in stock
£95.40
Add to wishlist
Delivery
Standard 3-5 working days
Ultra Slim is the world's thinnest flat to wall mounting solution at less that 0.84cm - yes that's only 8.4mm! - making it almost invisible once installed. Designed for the next generation of super slim LCD panels this product is a step ahead of anything else available in the market. Own the most discrete wall mount ever developed with the Ultra Slim range from Peerless.
Peerless Slimline Universal Ultra-Thin Flat Wall Mount SUF660P - mounting kit
Mounting kit
Mounting Components
Wall plate, bracket adapter
90 cm x 1 cm x 55.1 cm
2.6 kg
Recommended Use
LCD / plasma panel
Recommended Display Size
40"-80"
Max Mounting Pattern Size
825 x 449 mm
Max Load Weight
68 kg
Material
Cold-rolled steel
High-gloss black
5 years warranty
90 cm
1 cm
55.1 cm
2.6 kg
Material
Cold-rolled steel
High-gloss black
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD / plasma panel
825 x 449 mm
40"-80"
Max Load Weight
68 kg
Sorted-For-You, scratch-resistant
Limited warranty - 5 years
Scroll to top
