BT.com
Wishlist
Peerless-AV Ultra-Slim Universal Articulating Wall Arm for 42" to 90" Ul
Peerless-AV Ultra-Slim Universal...
£292.14
£292.14
Add to wishlist
Delivery
Standard Due date unavailable
The Peerless-AV universal ultra-slim articulating wall mount is designed exclusively for ultra-thin displays. Featuring a dual-arm construction, the SUA771PU is robust enough to hold larger displays firmly in any position - landscape or portrait - while still offering an ultra-low profile. An advanced I-shaped adapter plate makes it easy to access the back of the display, keeping hardware hidden, and features internal cable management, providing a clean, professional look that transitions smoothly from the wall to the display. With a gloss finish, the SUA771PU matches any decor. Full-motion capabilities allow you to swivel, tilt, extend or retract your display for the perfect viewing angle.
Peerless-AV Designer Series SUA771PU - wall mount
Wall mount
81.9 cm 44.2 cm
Adjustable Depth
4.7-63.1 cm
Tilt
-5° to 15°
Rotation
-90° to 90°
10.45 kg
Recommended Use
LCD / plasma panel
Recommended Display Size
42"-90"
Flat Panel Mount Interface
200 x 200 mm, 400 x 300 mm, 400 x 200 mm, 400 x 400 mm, 800 x 400 mm, 600 x 400 mm, 300 x 200 mm, 200 x 100 mm, 300 x 300 mm
Max Load Weight
57 kg
Material
Fused epoxy
Gloss black
Package Content
Mounting hardware
5 years warranty
81.9 cm
44.2 cm
Adjustable Depth
4.7-63.1 cm
10.45 kg
Material
Fused epoxy
Gloss black
Package Content
Mounting hardware
AV Furniture
Wall mount
Mounting Components
Articulating wall mount
Recommended Use
LCD / plasma panel
Cable Management
Integrated cable management
42"-90"
Tilt
-5° to 15°
Rotation
-90° to 90°
Adjustments
Roll, levelling, tilt
Max Load Weight
57 kg
Limited warranty - 5 years
Scroll to top
