BT.com
Wishlist
Peerless-AV TruVue Tilting Wall Mount for 37-75" LCD & Plasma Displays
Peerless-AV TruVue Tilting Wall...
£42.25
39 in stock
£42.25
Add to wishlist
Delivery
Standard 3-5 working days
Easily install large screens with this simple, intuitive mounting solution. Its simple hook-on installation combined with its toolless tilt angle adjustment enables LCD and plasma flat panel screens to be installed and adjusted quickly. Cables are easily managed behind the screen with large access ports in the wall plate.
Peerless Tru Vue TRT650 - wall mount
Wall mount
76 cm x 7.9 cm x 72.8 cm
Recommended Use
LCD / plasma panel
Recommended Display Size
37"-75"
Max Mounting Pattern Size
700 x 400 mm
Max Load Weight
10 kg
Black powder coat
5 years warranty
76 cm
7.9 cm
72.8 cm
Black powder coat
AV Furniture
Wall mount
Mounting Components
Tilt wall mount
Recommended Use
LCD / plasma panel
700 x 400 mm
37"-75"
Max Load Weight
10 kg
Integrated spirit level
Limited warranty - 5 years
Scroll to top
