BT.com
Wishlist
Peerless-AV TruVue Tilting Wall Mount for 26-46" Displays
Peerless-AV TruVue Tilting Wall...
£35.59
40 in stock
£35.59
Add to wishlist
Delivery
Standard 3-5 working days
Easily install mid-sized LCD screens with this simple, intuitive mounting solution. The simple hook-on installation combined with its toolless tilt angle adjustment enables flat panel screens to be installed and adjusted quickly. Cables and cords are easily managed behind the screen with large access ports in the wall plate.
Peerless Tru Vue TRT640 - wall mount
Wall mount
49 cm x 7.8 cm x 42.8 cm
Recommended Use
LCD / plasma panel
Recommended Display Size
26"-46"
Max Mounting Pattern Size
400 x 400 mm
Max Load Weight
40 kg
Black powder coat
5 years warranty
49 cm
7.8 cm
42.8 cm
Black powder coat
AV Furniture
Wall mount
Mounting Components
Tilt wall mount
Recommended Use
LCD / plasma panel
400 x 400 mm
26"-46"
Max Load Weight
40 kg
Integrated spirit level
Limited warranty - 5 years
Scroll to top
