BT.com
Wishlist
Peerless-AV TruVue Tilting Wall Mount for 10-24" Displays
Peerless-AV TruVue Tilting Wall...
£13.68
4 in stock
£13.68
Add to wishlist
Delivery
Standard 3-5 working days
This sleek, compact tilting wall mount delivers a big impact for small screens. Its simple hook-on installation combined with its adjustable tilt allows small LCD screens to be installed and adjusted quickly. The tilt angle can be adjusted without the use of tools to give an enhanced viewing position.
Peerless Tru Vue TRT630 - wall mount
Wall mount
11.44 cm x 4 cm x 11.3 cm
Recommended Use
LCD display
Recommended Display Size
10"-24"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
20 kg
Black powder coat
5 years warranty
11.44 cm
4 cm
11.3 cm
Black powder coat
AV Furniture
Wall mount
Mounting Components
Tilt wall mount
Recommended Use
LCD display
10"-24"
Max Load Weight
20 kg
Integrated spirit level
Limited warranty - 5 years
Scroll to top
