BT.com
Wishlist
Peerless-AV TruVue Flat-to-Wall Mount for 26-46" Displays
Peerless-AV TruVue Flat-to-Wall...
£24.64
32 in stock
£24.64
Add to wishlist
Delivery
Standard 3-5 working days
Create a sleek and stylish flat panel installation with this easy to install low-profile flat wall mount. Its design is simple and intuitive to use - just attach the wall plate, attach the screen adaptors to the flat panel and hook onto the wall plate. Cables are easily managed behind the screen with large access ports in the wall plate.
Peerless Tru Vue TRF640 - wall mount
Wall mount
45.6 cm x 43 cm x 2.8 cm
1.68 kg
Recommended Use
LCD / plasma panel
Recommended Display Size
32"-50"
Flat Panel Mount Interface
Up to 400 x 400 mm
Max Mounting Pattern Size
400 x 400 mm
Max Load Weight
32 kg
Matt black
5 years warranty
45.6 cm
43 cm
2.8 cm
1.68 kg
Matt black
AV Furniture
Wall mount
Mounting Components
Wall plate, universal mount, mounting hardware, bubble level
Recommended Use
LCD / plasma panel
Up to 400 x 400 mm
400 x 400 mm
32"-50"
Max Load Weight
32 kg
Integrated spirit level
Limited warranty - 5 years
Scroll to top
