BT.com
Wishlist
Peerless-AV TruVue Black Articulating Wall Mount for 22-40" Displays
Peerless-AV TruVue Black...
£51.69
16 in stock
£51.69
Add to wishlist
Delivery
Standard 3-5 working days
It is easy to get the best viewing options by pulling out the display from the wall, positioning it in almost any direction, even turning it around corners and then smoothly returning it to the wall when finished. With cable management, cords and cables and never in the way.
Peerless Tru Vue TRA732 - wall mount
Wall mount
24.7 cm 23.1 cm
Adjustable Depth
9.8-37.8 cm
Adjustments
Tilt
Recommended Use
LCD display
Recommended Display Size
22"-40"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm, 200 x 200 mm
Max Load Weight
15 kg
Black powder coat
5 years warranty
24.7 cm
23.1 cm
Adjustable Depth
9.8-37.8 cm
Black powder coat
AV Furniture
Wall mount
Mounting Components
Articulating wall mount
Recommended Use
LCD display
22"-40"
Adjustments
Tilt
Max Load Weight
15 kg
Swivel adjustment
Limited warranty - 5 years
Scroll to top
