BT.com
Wishlist
Peerless-AV Tru Vue TRVT560 Mobile Height Adjustable Trolley 32"-60"
Peerless-AV Tru Vue TRVT560 Mobile...
£238.58
More than 50 in stock
£238.58
Add to wishlist
Delivery
Standard 1-3 working days
The TruVue TRVT560 provides a sleek and tidy mobile solution for 32"-60" displays. Complete with 2 heavy duty poles to display the screen at a maximum height of 1500 mm (59").
Its unique and convenient TV height adjustment is complimented by spring plunges providing 90-degree adjustments for landscape and portrait viewing, cable management, and 4 heavy duty braked caster wheels. The TRVT560 also comes with a spacious metal shelf for AV component.
Peerless Tru Vue TRVT560 - cart
Cart
84.1 cm x 72 cm x 117.9 cm
Tilt
30 kg
Recommended Use
LCD / plasma panel
Recommended Display Size
32"-60"
Flat Panel Mount Interface
200 x 200 mm, up to 800 x 500 mm
Max Load Weight
45.5 kg
Powder coat, smooth matte black
Wheels Qty
4
5 years warranty
84.1 cm
72 cm
117.9 cm
30 kg
AV Furniture
Cart
Recommended Use
LCD / plasma panel
Cable Management
Integrated cable management
32"-60"
Tilt
Max Load Weight
45.5 kg
Wheels Qty
4
Adjustable height, locking casters, portrait to landscape movement, metal shelf
Limited warranty - 5 years
Scroll to top
