BT.com
Wishlist
Peerless-AV Trolley For 32" - 75" Flat Panel, Height adjustable w/ Shelf
Peerless-AV Trolley For 32" - 75"...
£530.04
Hurry, only 2 left in stock!
£530.04
Add to wishlist
Delivery
Standard 1-3 working days
The Full Featured SR575M Flat Panel TV Cart takes standard cart to the next level, making everyday usage more enjoyable. Height adjustment of the display and component shelf can be made without the removal of the TV by simply repositioning to your desired height and the fear of damaging doorways and walls has been averted by non-marring bumpers on each corner of the cart allowing even easier mobility from room to room while the UL certification ensures you that it can be done with safety in mind.
Peerless-AV SmartMount SR575M - cart
Cart
90.8 cm x 76.2 cm x 1.736 m
Tilt
-5°
31.8 kg
Recommended Use
LCD / plasma panel
Recommended Display Size
32"-75"
Flat Panel Mount Interface
Up to 600 x 400 mm, from 200 x 200 mm
Max Load Weight
68.2 kg
Material
Aluminium
Black powder coat
Wheels Qty
4
5 years warranty
90.8 cm
76.2 cm
1.736 m
31.8 kg
Material
Aluminium
Black powder coat
AV Furniture
Cart
Recommended Use
LCD / plasma panel
Cable Management
Integrated cable management
32"-75"
Tilt
-5°
Max Load Weight
68.2 kg
Wheels Qty
4
Adjustable height, locking casters, swivel adjustment, swivel casters, security hardware, height-adjustable shelf
Limited warranty - 5 years
Scroll to top
