BT.com
Wishlist
Peerless-AV Trolley Cart for Smart Kapp Capture Board
Delivery
Standard 1-3 working days
The SR542-KAPP Cart has been designed to include features and aesthetics to match the capture board. Height adjustment, tilt, and internal cable management complimented by an attractive finish make this cart stand out from the rest. Designed for use with the Smart kapp™ 42" capture board, the trolley provides a robust and sturdy solution ideal for sharing information in all types of applications.
  • Dedicated adaptor to fit SMART kapp™ 42" interactive whiteboard
  • Pre-assembled base provides rigidity, stability and quick assembly
  • Integrated cable management protects, contains and conceals cables for a clean, professional installation
  • Maneuvers easily with swivel casters, two locking
  • -5° tilt adjustment for optimal viewing position
  • Security hardware prevents tampering and theft
  • Lightweight aluminium construction
  • Durable powder coated finish to withstand the wear & tear of everyday use
Peerless-AV professional SR542-KAPP - cart
Cart - lockable
176.8 cm
Tilt
-5°
26.8 kg
Recommended Use
Interactive whiteboard
Recommended Display Size
42"
Flat Panel Mount Interface
400 x 400 mm
Material
Aluminium
White
176.8 cm
26.8 kg
Material
Aluminium
White
AV Furniture
Cart
Recommended Use
400 x 400 mm
Lockable
42"
Tilt
-5°
Scroll to top
