BT.com
Wishlist
Peerless-AV Tilting Wall Mount for Panasonic 103" Displays
Peerless-AV Tilting Wall Mount for...
£826.53
£826.53
Add to wishlist
Delivery
Standard Due date unavailable
Designed to fit one of the largest screens on the market today, this tilting wall mount makes installation simple and quick. The vertical screen adaptor brackets attach onto the screen with spacers provided.
Peerless-AV PANA103MTV - mounting kit
Mounting kit
Mounting Components
2 wall plates, 2 tilt plates, 4 lock tabs, 8 washers, 4 clevis pins, 4 cotter pins, 8 SAE washers
14 cm x 19.5 cm x 130.5 cm
Recommended Use
Plasma panel
Recommended Display Size
103"
Max Load Weight
226.8 kg
Matte black powder
TH-103PF12E, 103PF12EK, 103PF12U, 103PF12W, 103PF9EK, 103PF9ES, 103PF9UK, 103VX200, 103VX200C, 103VX200U, 103VX200W
14 cm
19.5 cm
130.5 cm
Matte black powder
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Plasma panel
103"
Adjustments
Tilt
Max Load Weight
226.8 kg
Panasonic TH-103PF12E, 103PF12EK, 103PF12U, 103PF12W, 103PF9EK, 103PF9ES, 103PF9UK, 103VX200, 103VX200C, 103VX200U, 103VX200W
Scroll to top
