BT.com
Wishlist
Peerless-AV Tilt Wall Mount With Media Device Storage for 40" to 60" LFD
Peerless-AV Tilt Wall Mount With...
£131.56
£131.56
Add to wishlist
Delivery
Standard 1-3 working days
Designed to hold a display and media device, the DST660 is the ideal low profile solution for digital signage applications. An open wall plate for easy outlet access, various tilt options and portrait/landscape ability add to its versatility. The universal design accommodates VESA patterns from 200 x 100 up to 400 x 400mm. For 600 x 400 and 800 x 400mm patterns, the ACC-V800X is available. In addition, component storage access is simple with the bottom disengaging design allowing the display to have a negative tilt that enables quick and easy computer maintenance without having to remove the display.
Peerless Flat/Tilt Wall Mount with Media Device Storage DST660 - wall mount
Wall mount
47 cm x 7.2 cm x 43.6 cm
Adjustments
Tilt
5 kg
Recommended Use
LCD / plasma panel
Recommended Display Size
40"-60"
Flat Panel Mount Interface
400 x 400 mm, 200 x 100 mm
Max Load Weight
57 kg
47 cm
7.2 cm
43.6 cm
5 kg
AV Furniture
Wall mount
Mounting Components
Tilt wall mount, media strap
Recommended Use
LCD / plasma panel
40"-60"
Adjustments
Tilt
Max Load Weight
57 kg
Horizontal or vertical installation
Scroll to top
