BT.com
Wishlist
Peerless-AV SmartMount Universal Tilt Wall Mount for 39" to 80" Flat Panel Displays
Peerless-AV SmartMount Universal...
£93.48
£93.48
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Wednesday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Ideally suited for extra large LCD and plasma screens, the SmartMount ST660P tilting wall mount allows you to mount your LCD/plasma screen quickly and easily and tilt it forward/back for an improved viewing angle.
Peerless SmartMount Universal Tilt Wall Mount ST660P - mounting kit
Mounting kit - wall-mountable
Mounting Components
Fasteners, bracket, tilt wall plate
76.6 cm x 7.3 cm x 45.7 cm
Adjustments
Tilt
4.67 kg
Recommended Use
LCD / plasma panel
Recommended Display Size
39"-80"
Flat Panel Mount Interface
Up to 824 x 405 mm
Max Load Weight
90.7 kg
5 years warranty
76.6 cm
7.3 cm
45.7 cm
4.67 kg
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD / plasma panel
Placing / Mounting
Wall-mountable
Up to 824 x 405 mm
39"-80"
Adjustments
Tilt
Max Load Weight
90.7 kg
Sorted-For-You
Limited warranty - 5 years
Scroll to top
