BT.com
Wishlist
Peerless-AV SmartMount Universal Tilt Wall Mount for 37" to 75" Displays
Peerless-AV SmartMount Universal...
£77.89
More than 50 in stock
£77.89
Add to wishlist
Delivery
Standard 3-5 working days
Ideally suited for large LCD and plasma screens, the SmartMount ST650P tilting wall mount allows you to mount your LCD/plasma screen quickly and easily and tilt it forward/back for an improved viewing angle.
Peerless SmartMount Universal Tilt Wall Mount ST650P - mounting kit
Mounting kit - wall-mountable
Mounting Components
Fasteners, bracket, tilt wall plate
76.6 cm x 7.3 cm x 45.7 cm
7.7 kg
Recommended Use
LCD / plasma panel
Recommended Display Size
37"-75"
Flat Panel Mount Interface
Up to 742 x 405 mm
Max Load Weight
79.4 kg
5 years warranty
76.6 cm
7.3 cm
45.7 cm
7.7 kg
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD / plasma panel
Placing / Mounting
Wall-mountable
Up to 742 x 405 mm
37"-75"
Max Load Weight
79.4 kg
Sorted-For-You
Limited warranty - 5 years
Scroll to top
